01-16-2022
06:53
20:37
01-16-2022
06:53
20:37
My new versa 3 uses very little battery during the day, but at night when it is doing so much work, it drains 20-30%. I’ve turned off everything that I didn’t have on my versa 2, yet it still drains. II wonder if it is because of Fitbit premium free trial that came installed on my versa when I got it (I selected to try it for 90 days)? I do not seem to be able to cancel it. I’d like to stop the night time battery drain. My Fitbit battery lasts 4 days at best. Are others experiencing this?
01-17-2022 03:48
01-17-2022 03:48
I think the big drainer with premium is the snore detection.
Check to make sure that is turned off.
Account/Activity & wellness/sleep
Very bottom option.
01-16-2022 07:34
01-16-2022 07:34
Hi @Jillikins - The night time issue is because of the new features and battery drainers - remove any you don't absolutely need and see if it improves - How to resolve the Major issues causing short battery life.
Best Answer01-16-2022 10:25
01-16-2022 10:25
Best Answer01-16-2022 10:31
01-16-2022 10:31
@Jillikins - Premium per se does not affect battery life but options you can choose with it, can, but they are listed in the link.
Best Answer01-17-2022 03:48
01-17-2022 03:48
Very bottom option.
01-17-2022 09:46
01-17-2022 09:46
01-17-2022 09:47
01-17-2022 09:47
