07-17-2020
04:51
11:59
DavideFitbit
07-17-2020
04:51
11:59
DavideFitbit
Hello,
I have a Versa 2 watch. I bought it for the sleeping functions. The first night it worked great. I have the details of my sleep, rem, light, deep, how much awake, etc... the second night, it is simplified. No details. I used the start sleep log both nights. As far as I know the same setup. The first night I wore it backwards on the non dominate hand.
what can I do for consistence reading?
07-17-2020 06:37
07-17-2020 06:37
The device needs to be able to detect your heart rate in order to create the detailed report. If it can't get a good read of the HR then it just relies on movement and your get the short version. It seems likely that the second night the sensor was not in good contact with your wrist.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
07-17-2020 18:17
07-17-2020 18:17
Thank you for the information. We will place it with thought.
07-17-2020 18:29
07-17-2020 18:29
Let me know how it does. Try not to make it too tight.
07-18-2020 03:45
07-18-2020 03:45
We only got the basic sleep log again. 😕
07-18-2020 03:55
07-18-2020 03:55
The heart beat is working when we go to bed. No errors or information on why it is not working. We wore it backwards like the first night. I did a firmware upgrade this morning. I trying to find what version I’m on now.
