05-17-2018
01:28
12:36
HeydyF
05-17-2018
01:28
12:36
HeydyF
I bought my versa solely on the basis that I would be able to connect my wireless headphones to it and leave my phone in the car. However when I try to pair the watch to the headphones it says it’s searching then says still searching, then says no devices found. I’ve tried restarting the watch with the bottom and back button trick. My headphones are in pairing mode because it tells me, but will not sync. This is huge for me as I don’t want to carry my phone in the gym. Any solution to get this feature to work will be much appreciated.
05-18-2018 12:35
05-18-2018 12:35
Hey @Cashfit, welcome to the Community! In order for you to pair Bluetooth headphones to your Versa, beside making sure that both, the device and your watch are in pairing mode, they need to be nearby. If they are but still not connecting, turn off/on the Versa and then try to pair them again.
Let me know if that works!
12-05-2018 16:07
12-05-2018 16:07
Same exact thing happening to me... nothing that has been suggested works for me. I'm frustrated.
12-05-2018 16:07
12-05-2018 16:07
12-05-2018 18:09
12-05-2018 18:09
Same exact thing is happening to me but the weird part is that before I had put any music on my versa I was able to connect the headphones. Now that I have music on it, I can’t pair
12-10-2018 10:53
12-10-2018 10:53
This is just one of the many problems I'm having setting up my Versa that I bought yesterday. I'm trying to pair my Samsung phone and my LG wireless headphones with my Versa. I go to Settings on my Versa, scroll down to Bluetooth, make sure the pairing question is marked On, then tap to add Audio Device. It says "Searching" then "Still Searching" then "No Devices Found" . Both my phone and headphones are turned on and mere inches away from my Versa. Have tried restarting Versa, restarting phone, turning headphones Off/On. This is so ridiculous.
11-11-2019 18:09
11-11-2019 18:09
Hi! It's been a while but have any of you found solutions to the Bluetooth pairing problem? I have the same issue with my new Versa.
10-18-2021 11:13
10-18-2021 11:13
Nope I've tried everything too and it still won't do a simple thing like connect to my phone for music controls. I've tried every possible workaround on multiple devices. This will be the last Fitbit purchase I make.
