11-27-2021
08:14
16:06
DavideFitbit
11-27-2021
08:14
16:06
DavideFitbit
I am no longer receiving my texts to my Versa 2. I have all the correct settings on yet none of my messages appear on the device. Calendar reminders still do as do calls, but no matter how many times I redo the settings I can’t get my messages to appear.
11-27-2021 16:05 - edited 11-27-2021 16:05
Hello, thank you for all the information that you've provided regarding the problem that you've been experiencing with your Versa 2 and the troubleshooting steps that you already tried, @AcuAdela.
Before considering other options, make sure to follow all the steps listed here to resolve problems with notifications. This has been useful for other users experiencing the same problem.
In addition to the steps mentioned earlier, make sure that you have the latest version of the Fitbit app installed and to check all the compatibility requirements here. Keep in mind that you need Android OS 8.0 or higher or Apple iOS 13 or higher on your phone and that you won’t see notifications on your Fitbit device if you turned on the Do Not disturb Icon or Sleep Mode.
Hope this helps, I'll be around.
11-27-2021 17:23
11-27-2021 17:23
I found the trouble shooter in the thread and it worked! Thank you!
12-03-2021 11:12
