05-09-2018 13:46
05-09-2018 13:46
I don't have a mobile device so I can't set up my Versa. If I set it up on my nephew's mobile device will I be able to view information from it on my computer? Is there anything I can do other than return the Versa or buy a mobile device?
05-09-2018 13:51
05-09-2018 13:51
Hi @BirdieII,
If your computer has Bluetooth 4.0 connection, you can set up the Versa on your computer. Just go to www.fitbit.com/setup and download the version for your computer's operating system. You'll need the computer anyway to sync and view the data, so you may as well set up the Versa on the same computer. Let us know if you need more help along the way.
05-09-2018 14:46
05-09-2018 14:46
05-09-2018 14:47
05-09-2018 14:47
I still ended up where it says in parentheses that a Versa and a couple other fitbits must use a mobile device.
