03-08-2023
05:36
08:14
03-08-2023
05:36
08:14
I am currently using the fitbit versa 3, upgraded from 2 as the versa 2's heart rate sensor stopped working and now the versa 3 does not allow you to store music execpt if u use spotify premuim or deezer. So, I bought spotify premium and now it says you can only play music from a device not store it on the watch......a big disappointment.
03-08-2023 22:48
03-08-2023 22:48
Hi @jimbe0 - unfortunately Spotify premium only allows you to use the watch app to control the phone playing, it doesn't allow storing of music on the watch. The other options which do, won't work after this month as they are being discontinued, so there will be no means to play music without a phone.
Note: Instead of using the Spotify app on the watch if you use the built-in Music controls you can control ANY music playing on the phone AND change volume WITHOUT stopping what you are doing with the watch and you won't need Spotify premium to do it.
