No oxygen sensor
ANSWERED
The only reason I bought the fitbit versa is for the o2 sensor and to log my sleep patterns.   I think you should take this back next give me my money back.  Don't advertise something you don't have !!!
1 BEST ANSWER
Accepted Solutions
If you purchased from Fitbit, you can get your money back, perhaps for 90 days.
ETA: 45 days, not 90; sorry, I should have checked return time period to be sure before posting that.
8 REPLIES 8
Just bs why would they say it did something like that
It does have the SPO2 sensor; it's just not in use yet, at least that we can see.  Perhaps it is harder than anticipated to get good results or to make the results useful.
Amazon sell Oximeters. One I have is just as accurate as the same my medical practitioner uses.
Blaze, Surge, Ionic and Versa1. I am not a FitBit employee.
I need one to monitor my oxygen while I sleep.
@Falseadvertisng  Just to clarify, Fitbit's no questions asked return period is 45 days.
Laurie | Maryland
Yah like a dumb **ahem** I waited to long for there update for there o2 sensor
I want to know if my oxygen level is in the 95-100% range, which would be the normal range.  I don't understand what value there is in knowing how much the oxygen level varies overnight, if you don't know what percent it is.   Are there any plans to tell us what our oxygen level percentage is??
Thank you in advance.
