04-16-2018 14:27
04-16-2018 14:27
I know it's a new watch but tried everything to obtain text and phone calls on it. There is no menu items for these in the device notification settings?? Everything worked well on Zenwatch 3 (sent it back) and worked perfectly on Pebble steel but I've spent all afternoon trying to get it to work no luck. Any help?
Best Answer04-16-2018 15:28
04-16-2018 15:28
I am also not getting any notifications. I even tried to "sent a test notification" and I haven't received anything. Eager see what other people have tried.
04-16-2018 15:28
04-16-2018 15:28
04-16-2018 15:32
04-16-2018 15:32
Also will not allow my own emails .appears it only let's get mail from Gmail or did I miss something $
Best Answer04-16-2018 16:34
04-16-2018 16:34
I am also not getting my text or email notification to show up I the watch
Best Answer04-16-2018 16:36
04-16-2018 16:36
Have you tried these instructions? https://help.fitbit.com/articles/en_US/Help_article/1979
See page 28 here. https://staticcs.fitbit.com/content/assets/help/manuals/manual_versa_en_US.pdf
Best Answer04-16-2018 16:40
04-16-2018 16:40
Yes I've played with all the notification menus I can find sadly nothing works I guess I've got to find a smart watch and not fitness tracker with some bits stuck on that really do not work .
Best Answer04-16-2018 16:43
04-16-2018 16:43
So I have a Pixel 2 and I actually turned off Auto-Sync as it kept not syncing and messing up the blue tooth. Since I did that, it's been giving my notifications.
Best Answer04-16-2018 18:17
04-16-2018 18:17
04-16-2018 19:02
04-16-2018 19:02
Thinking I'll be right behind you quite disappointed Back to the research to replace my Pebble steel
Best Answer04-16-2018 19:06
04-16-2018 19:06
I'm not getting any notifications either. I thought I had it switched or I'm not getting any notifications but no, I am.
Want Spotify for Versa? Click Here to Vote!
Click Here to Vote for Low Power Mode!
Best Answer04-17-2018 13:17
04-17-2018 13:17
Since I have turned off All Day Sync, my watch is continuing to sync every time I open the app and I am now continuously (as off the last 24 hours/since I bought it) receiving all notifications that I chose to allow to go through.
Best Answer04-17-2018 13:45
04-17-2018 13:45
if phone is on silient there isn't any way to get notifications. This is a new thing with fitbit as this didn't happen on the ionic and no the versa. I will return the versa if this isn't fixed. Who wants their phone ringing at work?? Part of the reason to have a smartwatch is so you don't have to look at your phone.
04-17-2018 13:48
04-17-2018 13:48
I had the same problem and i found these instructions worked for me
BUT
it didnt work the first day, only after using it on the second day the apps appeared in the notifications section in settings. The first day this had 0 apps there that i could turn notifications on for.
however once you fix this problem you will find that the notifications dont wake the screen so you cant see them anyway!
Best Answer08-08-2019 12:02
08-08-2019 12:02
My text and phone call will not go thru fitbit watch why
Best Answer08-08-2019 12:03
08-08-2019 12:03
Please help I cant get no text or phone call on Fitbit watch
