No silent alarms on Versa 3
ANSWERED
Versa 3 does not have silent alarm even tho it says it does.  Fitbit appears to have no customer support unless you’re on “twitter.” Which I am not. I bought the watch 2 months ago and have not used it.  Any advice how I can g
1 BEST ANSWER
Accepted Solutions
Hi, @dmkl8 , your Versa definitely has silent alarms!  From the clock face swipe left to scroll through the apps.  The alarms app has an icon that looks like an old fashioned alarm clock.  Tap to open and set alarms.
If you have swiped through all the apps and cannot see the alarm clock icon, then it may have been accidentally removed from your device.  In that case go to your phone app, and from the opening screen tap on the person photo/icon top left, then on the next screen tap on the picture of your Versa 3.  Find that “Gallery” tab to see available apps to download.  Choose the alarms app and add it to your Versa.  Be sure to sync your Fitbit whenever you make any changes in the phone app so that the changes are reflected on your device.
I hope this helps.  Please post again if anything is unclear.  Welcome to the Community Forums!
**Edited because the OP kindly marked my post as a Best Answer I slightly edited it to help other users to hopefully make it a little clearer when I was talking about the phone app rather than the app on the Versa itself
4 REPLIES 4
Hi there, @dmkl8. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 3.
In addition to the information shared by @Julia_G, please see How do I manage alarms on my Fitbit device?
Thanks Thank you very much. I found a lot of conversations and com0la8nts on the subject on the website but nothing explaining that it can be done, and how, until your response.
@dmkl8 if you are referring to my response then I would be grateful if you could mark it as “best answer”.  That will help other users find help if they are having the same issue, and also will make me happy 😀.
