06-21-2022
22:15
17:53
06-21-2022
22:15
17:53
Only had my Versa 3 for 2 nights and it’s only given me a sleep score for the first night. How do I get my sleep score for last night?
06-22-2022
11:29
09:56
06-22-2022
11:29
09:56
Hi, welcome to the Fitbit Community forums, @Rsln.
Thank you for sharing all this information about the problem that you've been having with your Versa 3.
Keep in mind that you must see sleep stages in order to see a sleep score. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
If you see sleep stages but don’t see a sleep score, please note that it may take a few minutes for your sleep score to appear. In addition, for better results please try to let the device detect that you're awake or asleep by itself rather than doing it manually and make sure to keep the Fitbit app and the devices' firmware updated to the latest version available.
The watch may need some days to collect some information (particularly regarding to heart rate) and provide sleep score, sleep stages and other data. Make sure that you've also tried the restart procedure described here and check if you continue to experience the same problem.
In case the problem is related to the Fitbit app, please try the following as well:
Best Answer06-22-2022 11:40
06-22-2022 11:40
10:28
08:35
07-06-2022
10:28
08:35
@Rsln Thank you for confirming that you already tried all the troubleshooting steps suggested.
In this case, since you continue to experience the same problem after all the steps shared in the forums, I recommend that you get in touch with the Customer Support team for further assistance with this. They will let you know how to proceed.
The best way to get help for this problem is to chat with us online or give us a call. You can click here to get connected
