11-19-2023
16:13
10:05
CrisVillaFitbit
11-19-2023
16:13
10:05
CrisVillaFitbit
Versa 3 stopped tracking sleep score about 3 weeks ago. It was giving daily scores regularly, then nothing. Tried updating and resetting but that did not work. No change to watch position on hand or sleep positions from when it was working. I looked at other questions and responses and am doing everything they suggest but still no results
Moderator edit: edited title to clarity
11-20-2023 10:04
11-20-2023 10:04
Hello, @LTP3 Welcome to the Fitbit Community.
Thanks for informing me about this situation with your Sleep Score on your Versa 3 and for the steps taken to solve this situation.
There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
- If you slept in a position that prevented your device from getting a consistent heart-rate reading or wore it too loosely. For best results, wear your device higher on your wrist (about 2-3 finger widths above your wrist bone). The band should feel secure but not too tight.
- If you used the Begin Sleep Now option in the Fitbit app (instead of simply wearing your device to bed). For more information on automatic sleep tracking, see this article.
- If you slept for less than 3 hours.
- If your device’s battery is critically low.
Taking this into consideration will help you getting your sleep score, for more information check this article.
11-20-2023 11:13
11-20-2023 11:13
11-22-2023 06:29
11-22-2023 06:29
I have the same problem with my Versa 3, also for about the last 2-3 weeks. I have also checked the above recommended actions with no change. It seems some investigation is required, not just send the standard reply.
11-22-2023 08:09
11-22-2023 08:09
I agree! I have had the same issue for the same amount of time. This seems like a universal issue with the platform and not with our individual devices.
11-23-2023 00:15
11-23-2023 00:15
I think it started after the new app was released? Maybe there was a software update about the time it started?
11-23-2023 21:36
11-23-2023 21:36
I too have the same problem like many many others since the last update. I am just still trying to talk to a human for some answers!!!!
11-29-2023 06:24
11-29-2023 06:24
I have had the same issue with my Versa 2 for the last 2 weeks.
11-30-2023 05:13
11-30-2023 05:13
I just checked my log & found that this started on 31st October. I want to contact a Fitbit person but cannot - no email, 24-hour chat not responsive, I don't use X or Tiktok.
12-01-2023 02:53
12-01-2023 02:53
I am having the same issue, it also started on 31st of October. It would be nice if a moderator could respond.
Best Answer12-01-2023 09:15
12-01-2023 09:15
Best Answer12-02-2023 22:54
12-02-2023 22:54
I believe I have discovered why this is happening. I just found a table showing what we get with the free Fitbit App versus the Premium Fitbit App. The free one now only gives the Sleep Score, & the premium one gives Sleep details. Therefore I am assuming that all of us are using the free app (I am). I do not intend paying for the premium app because I I not not use 80% of the features.
12-03-2023 09:25
12-03-2023 09:25
Best Answer12-04-2023 08:42
12-04-2023 08:42
I have also been having this issue with my versa 3. In the last week I haven't had a single sleep record properly and I haven't changed anything about the way I sleep. The last few nights I've even made sure to fall asleep on my back so the tracker isn't being moved around and it still isn't working.
