04-17-2020 06:46
04-17-2020 06:46
Why is there not a smart alarm on the alarm app. I see it in the app store, but it doesn't display it when I download the app.
04-18-2020 03:45
                              04-18-2020 03:45
@FitDudeMan Yes, you aren't seeing the Smart Alarm option because you don't have the latest firmware. When there is a firmware update available, there is a notice on your Fitbit app Today screen. Obviously not, in your case. If your Fitbit is really new, it might take a few more days for you to get the update. Another thing you can try is sync your Versa 2, remove it from your account, then set it back up as a new device. The extreme option is to sync your device, then do a Factory Reset (Settings > About > Factory Reset). BUT, and I do emphasize BUT, there is a Help article that specifically says don't do a factory reset unless you are told to do it by Support.
Laurie | Maryland
 Best Answer04-17-2020 07:44
                              04-17-2020 07:44
Hello @FitDudeMan and welcome to the Help forums. The Smart Alarm is part of the Alarm setting on the Versa 2 itself and shouldn't need an additional download. When you set an alarm, the Smart Wake option should be there on the screen when you set the alarm time. BUT, it looks like you are a new user with a new device. It's possible that your Versa 2 doesn't have the latest firmware. You can check your Versa 2 firmware in two places. On the Versa 2 itself, go to the Settings then scroll down to the bottom to About. Or tap on your profile picture on your app > Versa 2. The version is there. If you have the current firmware, the Versa 2 will say 35.70.7.21. The app says Version 70.7.21.
What firmware version do you have?
Laurie | Maryland
 Best Answer04-17-2020 15:19
04-17-2020 15:19
Sorry for the late response, my version is 35.68.9.15. Thanks you
 Best Answer04-18-2020 03:45
                              04-18-2020 03:45
Laurie | Maryland
 Best Answer04-18-2020 10:35 - edited 04-18-2020 10:36
Thank you, I will try to do that. How do you rank best answer.
Never mind I figured it out
