02-12-2019 11:52
02-12-2019 11:52
Hello first time posting- I usually search through the site hoping my question was asked and answered before but I haven't seen this.
I have had a versa since November and a flex two prior to that. I noticed when checking the weight that I've lost, in the "Lean vs Fat" graph there's calculations of supposedly the amount of both the lean and fat I've lost. I'm curious how accurate this is and how it's being calculated? I haven't seen anything on the app or mobile site that really explains it so any information would be appreciated!
02-12-2019 16:43
02-12-2019 16:43
@Denni_Jay I'm assuming at some point you logged your weight. In theory, one does not need to log body fat %, as it can be calculated from BMI. BMI can be calculated based on the inputted weight and other info from your profile. Of course, this kind of estimations are very inaccurate. To make it slightly more accurate, you would need extra body measurements.
02-12-2019 17:00 - edited 02-12-2019 17:00
@Marrrmaduke Oh okay I see- so does the BMI guesstimation also generates the numbers in what the lean pounds and fat pounds in the other charts I'm guessin
Thank you for the link! Definitely want to use it now.
02-12-2019 20:51
02-12-2019 20:51
@Denni_Jay yes. Use the second link to calculate your body fat (you will have to measure your body), which you can later input along with your weight. This would be more accurate than BMI 'guesstimation', especially for females. In the longer run, I would recommend getting a scale. I do have Aria and really like it. 😊
