01-18-2021
01:13
20:50
01-18-2021
01:13
20:50
I have a Versa 3 version 36.128.4.17 but I do not see the voice assistant tile in the app or my watch.
This is the latest firmware right?
What should I do there is no of het update. I live in the Netherlands.
Thanx
12-28-2021 05:03
12-28-2021 05:03
Hi @SunsetRunner - Yes, there's been a change, see What's new in the Fitbit app - Latest Update
12-28-2021 07:29
12-28-2021 07:29
Thanks for your reply 👍
12-28-2021 07:50
12-28-2021 07:50
10-15-2022 00:01
10-15-2022 00:01
I also wanted to use voice assistant after using the watch for a while but the app doesn't show me the "voice assistant" tile. Everything is up to date (app and Versa 3), reinstalled the app, nothing helps. Very frustrating...
10-15-2022 14:10
10-15-2022 14:10
@mawil149 have you tried holding on the button? This is the quick view menu and should be their by default.
10-15-2022 23:36
10-15-2022 23:36
You mean open the shortcut menu? It was there but when I tried to open the assistant it gave me an error. After that the voice assistant shortcut was replaced with the relax app and is no longer visible in the settings (where I can set the shortcuts).
