12-09-2024
16:53
08:32
EstuardoFitbit
12-09-2024
16:53
08:32
EstuardoFitbit
My son did a factory reset of my Versa 3 (don't ask, I did not know he was doing it...). Ever since then, it only scrolls multiple languages indicating that the Fitbit app needs to be downloaded. I have done all of the following:
I think I'm screwed. What do you think?
12-11-2024 07:01
12-11-2024 07:01
@rel2099 I really appreciate the quick answer, let's try a couple more things!
Thinking about something that we can try to resolve the issue, I'd like to see if performing a factory reset again might help.
Please let's try to doing it in this way:
- Press and hold the button for about 8 seconds until the screen turns off.
- After the screen turns off, you will feel a brief vibration.
- When you feel the vibration, release the button and immediately press and hold the button again.
- Wait until the blue logo appears and then disappear.
- Immediately release the button and then immediately press and hold it again, until you feel one more vibration.
- After you feel this vibration, release the button.
- This vibration indicates that you have started the factory reset.
Once the Fitbit logo appears, the device will display the image with the phone icon and the setup prompt. Set up your watch again by following the instructions: How do I set up my Fitbit device?
12-10-2024 08:29
12-10-2024 08:29
Hello there @rel2099, it is nice to see new members around the community!
I really appreciate all the time you've invested in getting your device back to work. Actually, all the steps you've already tried are really good, but sometimes the order of these steps can be key.
Let's try the next:
Once you have done that in that order, please try setting up your device once again. Make sure the Versa 3 is at least 50% battery and go for it!
12-10-2024 15:14
12-10-2024 15:14
12-11-2024 07:01
12-11-2024 07:01
12-11-2024 11:20
12-11-2024 11:20
Hi Estuardo. My problem is exactly the same that Roy has. Did your last guidance to him fix it please?
Peter
12-11-2024
11:40
04:33
EstuardoFitbit
12-11-2024
11:40
04:33
EstuardoFitbit
Estuardo -
Thank you so much - that worked! I thought for a while that the watch was
a gonner, but now it seems to be working just like it always has.
Thanks again!
Roy Leonard
Peter -
The process from the last post from Eduardo worked for me. I hope it works
for you, too. Good luck!
Roy
Moderator Edit: Merged reply
12-11-2024 13:55
12-11-2024 13:55
Roy
thank you for responding. I have had this problem for months and was about to give up. I was very unhappy that the Fitbit help team closed down their support. My limit with modern tech only goes as far as changing light bulbs! I’ll have another go tomorrow and hope I have the same success that you did. Well done.
Peter
12-12-2024 04:31
12-12-2024 04:31
That's amazing @rel2099, please let's give @Peter969 a warm welcome to the community!
I'm glad to read that my suggestion was helpful in resolving the issue with your device. @Peter969 You can always give it a shot to see if the suggestions can help you too.
I'll be around, guys, just in case you need anything else!
12-14-2024 11:17
12-14-2024 11:17
Thank you for responding and for your kind welcome to the community. I’m still having problems and wonder if my hardware is ok. I have an iPad OS 17.5.1, phone is Samsung galaxy A12 and I have an HP android laptop I would prefer not to use but am happy to do so if it will get my Versa 3 up and running again. I stand ready to go to factory settings and use a new password and will take any help you would like to offer.
Peter
12-14-2024 16:11
12-14-2024 16:11
