01-22-2022 22:08
01-22-2022 22:08
Hi, I did factory reset from settings in watch. After that i get fitbit icon and ask to download fitbit app to start. Now, I started setting up new device from fitbit app -> user profile -> choose fitbit versa 2.
After that i connect with charger and followed instructions. However app is not able to detect my watch and failed to connect. My device bluetooth is on and working(using LG wing android device) . It seems there is some problem to connect the device. Please advice.
Thanks in advance. Cheers.
01-23-2022 02:29
01-23-2022 02:29
Hi @i.shashikant - a good place to start is with logout of the Fitbit App and restarting both devices and turning off any other Bluetooth devices. How do I restart my Fitbit device?
01-23-2022 09:20
01-23-2022 09:20
Hi @Guy_ ,
Thanks for your suggestion. I tried but failed to connect with fitbit app. I tried another device (oneplus 6) but no luck. Pls help.
01-23-2022 09:29
01-23-2022 09:29
@i.shashikant- at this point it's probably best to contact Fitbit Support directly. They may be able to help you.
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
