04-22-2020 23:03
04-22-2020 23:03
Hi!
I purchased my versa lite 2 weeks ago. It does not reflect the right calories burnt when I am exercising despite the heart rate and exersice zones being shown correctly.
I exersiced 80 mins today and this was shown in my exersice zone - but the calories only showed 200 calories - which is definitely not right for a high intensity crossfit style workout.
Has anyone solved this issued before? Please help.
Thanks!
Best Answer04-23-2020 08:53
04-23-2020 08:53
Check that your weight is not set way too low - that would lead to low calorie burn.
Best Answer04-23-2020 16:46
04-23-2020 16:46
Hi! Thanks for getting back to me 🙂
Yes - just checked - the weight it set correctly. And I think the calorie burn for everything else ie normal resting calorie burn and even walking calorie burn is right.
The only issue is when I am exersicing - it seems to register this calori burn - just like my resting calorie burn.
Example - only a day I was up at 9am - it says i have burnt 400 cals (which is fine bassed on resting BMR) - but it also shows 400 cals burnt if I wake up at 6am and do a high intensity worksout for 80 mins.
And its weird because it does track the change in heart rate when i look into the app - there are peaks between the workout times.
10-05-2020 20:05
10-05-2020 20:05
I just got the same problem today with my Versa Lite. It was working fine but today it looks like I just sat and did nothing from 9am to 4pm. I rode my bike twice and it recorded that fine and if I drill down to the details on that, it shows the calories burned but the total calorie count doesn't include it. This is the first this has happened so I wonder if it's another problem with their firmware.
Best Answer10-06-2020 06:00
10-06-2020 06:00
Just a follow up to my post yesterday. At 9pm, the calorie read was only 1300 but when I checked the next day, the reading said it was 2000. I didn't burn 700 calories in my sleep. The graph still shows I did nothing from 9am to 4pm but I guess the internal mechanism kept track of the real count.
