03-09-2021 10:50
03-09-2021 10:50
03-09-2021 11:03
03-09-2021 11:03
Have a look at the suggestion posted here - it will help you work out the problem.
As its under warranty, if you can't get it working, probably best to contact Fitbit Support directly. They may be able to help you.
Best Answer03-09-2021 11:37
03-09-2021 11:37
Thanks, I’ll try that.
