Are you getting any other notifications (phone, email)? If everything is out, try press and hold the left button until you see a notifications tile and make sure notifications is turned on.
If it is only text that is missing, go to the phone app and tap on the upper right corner (icon looks like a document) and then tap the Versa tile. scroll down to the 'General' section and tap on notifications. From here make sure Text Message default is the app you want. If you have multiple text apps, tap on the App Notifications and scroll down and find the text apps and make sure they are turned on.
Hope this helps.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
Best Answer@Aboscia10 are you able to receive other notifications? Also what phone and operating system are you using?
