06-13-2018
11:39
16:51
EdsonFitbit
06-13-2018
11:39
16:51
EdsonFitbit
I just got my Versa yesterday, and so far, I am receiving call and text notifications just fine but not Google Calendar notifications.
I had an Alta previously, and it always sent me my Google Calendar events just fine.
I am not sure if this is a setting in the FitBit app or in Calendar, but I've tried adjusting permissions, turning off do not disturb, etc. I don't think it's a pairing issue as I am receiving all other notifications without issue or delay.
Moderator edit: added label
06-13-2018 16:20
06-13-2018 16:20
The setting is in the fitbit app. On the dashboard tap on the upper right corner to get the list of devices, then tap on the device tile. Scroll down to the General options and tap on Notifications. Tap on Calendar Events to make sure that a) it is turned on and b) the correct calendar app is selected. If you can't find the calendar app on this list then go back one screen and then tap the App Notifications tile and scroll down to find the correct calendar app and then turn that on.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
