11-29-2018
18:42
18:31
EdsonFitbit
11-29-2018
18:42
18:31
EdsonFitbit
I have a versa and it just stopped receiving text messages about a month ago and this week stopped recovering phone calls. My calendar items are there. It was working fine since May and then just stopped working. I’ve tried all the troubleshooting options I could find
Moderator edit: added label
11-29-2018 18:55
11-29-2018 18:55
@Lenza87 phone model, OS, versa firmware version, fitbit mobile app version?
Best Answer11-30-2018 03:59
11-30-2018 03:59
Best Answer11-30-2018 19:41
11-30-2018 19:41
@Lenza87 Let's try this first:
Also, go to your phone Settings > Notifications > Fitbit and make sure all notifications are enabled. If they are, disable everything, then restart your phone and enable everything back.
Best Answer12-01-2018 06:26
12-01-2018 06:26
Best Answer12-01-2018 20:22
12-01-2018 20:22
@Lenza87 Go to Fitbit mobile app and make sure Messages are enabled under Versa's Notifications. If they are, disable them, sync, and enable again. Sync. Can you also take screenshots of the Notification screen of the Fitbit mobile app and the Notifications under your phone Settings?
Best Answer12-02-2018 11:56
12-02-2018 11:56
Best Answer12-02-2018 17:51 - edited 12-02-2018 18:09
