Notification Vibrations--don't want
When I first got my Versa, I was able to swipe down to see notifications I had, but wasn't getting the vibration. I LOVED THIS. I do NOT want my wrist vibrating every time I get a text, but love to check every so often. However, I reset my settings for another issue, and now I am either getting vibrations with notifications. Is there a way to set it up so I ONLY swipe down to see the notifications, but don't get the vibrations? I had it before and want to have it again.
3 REPLIES 3
Duplicate post
Not to my knowledge. Have you tried turning notifications off through the quick menu? I believe this may be the setting that you want. I haven't tried it.
Hi, in the dashboard of your Fitbit app, press the watch icon on top of the screen on the right side. On the page you will see, scroll down to notifications and press it. Scroll down to just underneath  where it say "Settings for vibration" and disable "always vibrate". Now you should get on your Versa notifications without vibration. For certainty restart your Versa by going to setting, press it, scroll down to device info, press that and scroll down to "shutdown". You can start your Versa again by pressing the left button.
