08-29-2018
10:57
16:09
LizzyFitbit
08-29-2018
10:57
16:09
LizzyFitbit
Hello. I have Fitbit Versa, firmware version 32.32.10.15, mobile phone Xiaomi Redmi 5 plus and notifications are not running on my tracker. My phone reports an error: "Notification service not running. A phone restart is required to re-enable notification on your tracker".
I restarted bluetooth on my phone and also Fitbit app, also reinstall Fitbit app and it still doesnt work. Please, can you help me?
01-01-2020 09:34
01-01-2020 09:34
01-02-2020 23:51 - edited 01-03-2020 00:20
I had the same problem... After trying many of the solutions, I was allways getting the same problem after a few days or hours.
I am running Android on a Samsung J6.
Then, I realised that I moved the APP to "external storage" to save some internal space.
Moved it back to internal storage and immediatly the service was up and running, the "service not running" message disapeared.
Hope it works with you guys and girls.
01-03-2020 08:13
01-03-2020 08:13
Which phone you are using
01-03-2020 08:19
01-03-2020 08:19
01-03-2020 08:22
01-03-2020 08:22
01-04-2020 00:02
01-04-2020 00:02
01-04-2020 02:52
01-04-2020 02:52
@Altoastral that is a good point. When someone moves an app and things stop working.it is best to move the app back.
Part of the fitbit app gets embedded into the OS and apps like Fitbit have issues intercepting notifications when not in main memory.
01-10-2020 01:24 - last edited on 04-27-2020 20:07 by LiliyaFitbit
I don't know how, notifications started coming.
I didn't perform a single function.
It just happened automatically.
Ragards
01-10-2020 12:58
01-10-2020 12:58
I'm not having any luck. I got the Versa 2 for Christmas. It was sending me notifications until just 2 days ago. Now I can't seem to get anything aside from "get more steps". I've restarted, stopped and cleared (forcing logon again), looked at and changed battery optimization and more. So far, haven't uninstalled and reinstalled the app. May try that next. I'm on Android 7.0 from BLU. Considering it worked for over 2 weeks, I'm not thinking it's an issue with the phone.
Regards
Kevin
01-10-2020 23:10
01-10-2020 23:10
10 days, up and running.
01-11-2020 16:09
01-11-2020 16:09
I have the same issue with Mi MIX_1
1) I reinstalled app
2) Deleted cache after new install
3) Allow to vibrate on silent
4) Turn on/off/on notifications permissions
5) Given all permissions to app and locked to be always working and also added permission to autostart
6) Battery optimization off
Still not working BUT it was working in past! Stopped after the recent fitbit update, that update was in November or October...
I do not know what to do...
01-13-2020 13:45
01-13-2020 13:45
Well, my oddity got better. About an hour (or less) after posting my comment last week my Versa 2 starts buzzing away and suddenly a flood of messages and such came it. It's made it through the weekend still functioning that way. Hadn't done anything more than what was already said. Weird.
01-14-2020 02:59
01-14-2020 02:59
I am using Versa 2, often I am not getting any notifications, I tried the steps given in this community, but it's not working. Help me with this.
01-17-2020 08:42
01-17-2020 08:42
About a week later, and it's back. My phone got rebooted last night, and notifications stopped working after that. Not sure why rebooting a phone should kill the way the communication between devices work. It should be expected that one or the other will reboot at some time.
Getting the lovely "Notifications Service not running" and of course the steps have already been done. Redid the clearing Data and Cache. Bluetooth is on. Notifications are set to go. I've run manual sync multiple times. Steps and such all sync. Just can't get Notifications.
My next step might be to fully uninstall the app and reinstall. I really believe this whole thing started for me the last time after my phone was restarted. So something is not handling the phone restarts. Would help if I could pinpoint to a service.
K
01-19-2020 04:01
01-19-2020 04:01
I have clear storage and even did uninstall the aap.
It's hardly works for 5 min and again same problem 'notification not running'
01-21-2020 15:08
01-21-2020 15:08
I tried your solution but it didn't work for me. I use a redmi note 5 pro. Android version 9
01-30-2020 10:23
01-30-2020 10:23
Unistalled and reinstalled the app and it worked for almost 24 hours. Then it stopped again. This can't be a phone issue. Something with the app is not keeping the notification services alive.
K
01-31-2020 14:40
01-31-2020 14:40
Ok, finally got something that was easier and "consistent". I went into my phone's Settings. Searched for Notification Center, and then into "Access to notifications". I turned off the slider bar for FitBit, then turned it back on. It prompts for Allow access "blah, blah, blah... long message" all over again. However, now it works again, where a phone reboot, nor watch reboot did squat. Will it last more than 2 hours? I don't know. I've had to do it twice today already, so something is not sustaining the permission, even when the phone shows it's on.
Hope that helps someone.
K
02-01-2020 01:38
02-01-2020 01:38
Did that on my Versa 2 didn't help at all. Still the service not working.
02-10-2020 11:28
02-10-2020 11:28
Just traveled over the weekend. This included changing time zones on my phone. Initially could not get my Versa 2 to sync after the phone changed, no matter how many times I clicked to sync. After a while, for whatever reason, it finally worked. However, the notifications stopped again. Ended up doing the same thing again, turning the Notifications for FitBit off and on in the Notifications Center. Things started to work again. So far it's been a repeatable process to get it working.
