08-29-2018
10:57
16:09
LizzyFitbit
08-29-2018
10:57
16:09
LizzyFitbit
Hello. I have Fitbit Versa, firmware version 32.32.10.15, mobile phone Xiaomi Redmi 5 plus and notifications are not running on my tracker. My phone reports an error: "Notification service not running. A phone restart is required to re-enable notification on your tracker".
I restarted bluetooth on my phone and also Fitbit app, also reinstall Fitbit app and it still doesnt work. Please, can you help me?
09-12-2020 23:36
09-12-2020 23:36
Oh my gosh! It worked. I've been having this issue for....... And been in talks with fitbit over the last year loads of times as couldn't get it to work. I did actually give up and was starting to think what is the point of the fitbit device. This, though, is so easy to do and understand and boom works straight away again. Thank you so much. 😁
00:14
10:46
DavideFitbit
09-13-2020
00:14
10:46
DavideFitbit
Another fix worked for me (Xiaomi Redmi Note 5) with no need to clear app data:
1. go to the phone Settings.
2. navigate though "Passwords & security" -> "Privacy" -> "Special app access" to "Notification Access"
3. optionally disable Fit Notifications if you have it installed. If not, just jump to the next step
4. disable Fitbit (Fitbit Notification Service .
5. enable Fitbit (Fitbit Notification Service)
6. optionally enable Fit Notifications if you have it installed
7. Fitbit app now should not have the warning saying "Notification service is not running..."
For other Android phones there should be similar path to get through and re-enable notification service.
Hope this works for you.
please try this https://community.fitbit.com/t5/Other-Versa-Smartwatches/Notification-service-not-running/m-p/447656...
Moderator edit: merged replies
09-13-2020 14:11
09-13-2020 14:11
Thank you. I will try this as well.
Best Answer09-28-2020 03:26
09-28-2020 03:26
After searching a lot for my Honor 10 and trying all the "clear cache" and "disable-enable notification access solutions" I finally got it working and not crush every few hours. Something is shutting down the service working on the background, either by a 3rd party app either bys the OS.
I went to Setttings - Apps - Fitbit - Power Usage details - App launch - and unchecked manage automatically
Hope there is something like that as an option for you. I'm in Android 10.
Best Answer10-01-2020 06:23
10-01-2020 06:23
This worked.
Guys try this out.
Thanks !!!!!!
Was planning to return my fitbit
Best Answer10-09-2020 21:31
10-09-2020 21:31
Thank you so much for sharing this information! I've been attempting to correct this issue for days - weeks even. Finally, some information that works!
Best Answer11-03-2020 06:32
11-03-2020 06:32
Goto Mobile Setting and search there Notification access and then enable notification for fitbit app it will definitely works.
Best Answer11-03-2020 07:25
11-03-2020 07:25
This question is about the Fitbit app, not about the Fitbit hardware. To give a correct answer we will need to know which operating system the phone runs.
11-04-2020 14:26
11-04-2020 14:26
This works but in my case, I have to do it on a daily basis. I have a Xiaomi Black shark.
Best Answer11-04-2020 19:47
11-04-2020 19:47
Best Answer11-04-2020 23:53
11-04-2020 23:58
11-04-2020 23:58
Notification Access to fit bit app
Best Answer11-05-2020 05:32
11-05-2020 05:32
11-24-2020 00:23
11-24-2020 00:23
It worked, actually on oneplus some apps don't work under battery optimization, it was one of them.
Best Answer12-02-2020 05:49
12-02-2020 05:49
I have to do this more than once a day. I hope fitbit can fix this.
01-02-2021 14:23
01-02-2021 14:23
Thanks Rajesh, that worked. I just hope it doesn't keep needing to be done. I'd do a thumbs up vote but can't work out how. 😁
Best Answer01-03-2021 05:58
01-03-2021 05:58
Hi. I have the same issue once a week. I have to go to my phone settings, apps, fitbit and clear data.
It is an annoying issue though. How can it be reported to developers for fixing permanently?
Best Answer01-03-2021 07:39
01-03-2021 07:39
Best Answer01-03-2021 07:43
01-03-2021 07:43
I did the App data and it worked but the second the apps closed it loses the permissions. Unless I can find a way to keep app on permenantly I won't be getting texts.
Best Answer03-09-2021 10:25
03-09-2021 10:25
Hello
I try this tutorial from youtube and it work to me correctly.
This is the video
