12-23-2020
22:25
04:44
12-23-2020
22:25
04:44
Hi,
Am getting notification error restart required to re-enable notification, although I reboot my phone and cleared data in app settings it is being ok for the day and next day am getting the same error repeatedly.
12-24-2020 04:46 - edited 10-13-2023 03:56
Hi there @Sushma_1, welcome to the Community Forums. Thanks for trying to troubleshoot this situation before reaching out.
If you're getting this error message “Notification service is not running. A phone restart is required to re-enable notifications on your tracker”, please note that we’re aware of it and are working to identify a resolution as quickly as possible.
If you're not getting that error message, but having issues with your notifications, please follow these troubleshooting steps Why are notifications delayed or missing?. You can also try the steps below:
Note that you may see a message on your phone related to power consumption and apps scanning in the background. If you follow the steps in this message, the Fitbit app can’t run in the background and certain features may not work properly. Repeat the steps above to enable the Fitbit app to run in the background.
Please know Fitbit products are compatible with most devices that have the following operating systems: Apple iOS 12.2 or higher, Android OS 7.0 or higher, and Windows 10 version 1607.0 or higher. For the latest list of devices that support the Fitbit app for Android, see Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported and does not meet the require OS we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
We routinely test new devices to ensure full compatibility with Fitbit devices and the Fitbit app, and are constantly working to confirm compatibility with new phone models. Be sure to verify that your phone or tablet meets the minimum operating system requirements.
