04-15-2021 07:46 - last edited on 04-17-2021 05:24 by MarreFitbit
My versa 2 is not getting any notification, even though I checked everything in phone and in fitbit app it is continuously showing me to restart my phone,even I did that but still not able to get any notification, even I have restarted my fitbit also, but problem is still there. How can I solve?
04-17-2021 05:26
04-17-2021 05:26
Hi there, @Nehamehta. Welcome to the Community Forums. Thanks for troubleshooting the issue with your Versa 2 before reaching out.
If you're getting this error message “Notification service is not running. A phone restart is required to re-enable notifications on your tracker”, please note that we’re aware of it and are working to identify a resolution as quickly as possible.
However, if you have a Huawei phone you can try the following steps:
Note that you may see a message on your phone related to power consumption and apps scanning in the background. If you follow the steps in this message, the Fitbit app can’t run in the background and certain features may not work properly. Repeat the steps above to enable the Fitbit app to run in the background.
Hope that helps.
04-17-2021 05:26
04-17-2021 05:26
Hope that helps.
04-17-2021 06:19
04-17-2021 06:19
Thank You for your reply , as I have Oneplus Phone so the above solution will not work, but hope you find out the resolution quickly. Once Again thank you waiting for solution.
