Notifications are not coming through my Versa 2
ANSWERED
When i disconnecte the phone from my versa2 the next day when i sync the app the notification not work properly then continuously showing that restart your phone.after i restart the phone it won't be solve the issue.
1 BEST ANSWER
Accepted Solutions
Hi there, @Vaibhav7228. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
If you're getting this error message “Notification service is not running. A phone restart is required to re-enable notifications on your tracker”, please note that we’re aware of it and are working to identify a resolution as quickly as possible.
However, if you have a Huawei phone you can try the following steps:
  1. On your phone, open the Settings app > Apps and notifications > Apps.
  2. Tap Fitbit > Battery.
  3. Turn off the Power-intensive prompt option.
  4. Tap Launch.
  5. Turn off the Manage automatically option, and turn on the Auto-launch, Secondary launch, and Run in background options.
  6. Tap OK.
Note that you may see a message on your phone related to power consumption and apps scanning in the background. If you follow the steps in this message, the Fitbit app can’t run in the background and certain features may not work properly. Repeat the steps above to enable the Fitbit app to run in the background.
I've moved your post to the Other Versa Smartwatches for organization purposes.
Hope that helps.
1 REPLY 1
  4. Tap Launch.
  6. Tap OK.
Hope that helps.
