01-21-2022
16:54
04:13
01-21-2022
16:54
04:13
Hello everyone, please help if possible!
I have had my Fitbit for over a month now as a gift which I love.
However, I cannot get my notifications to happen at all - every time I set it up via the app, they will run for a few hours before I get the dreaded “Notification service not running. A phone restart is required to re-enable notifications on your tracker”
I am at my wits end! I’ve restarted my phone countless times, I’ve watched YouTube tutorials, I’ve been sure to keep the app running in the back ground, turned off data saver, I’ve even tried to do it it through my iPad in the hope that works - but it is just not happening!
I feel like I can’t get the full use from my tracker and I’m really frustrated. Fitbit what is happening?
Hopefully someone can offer me a saving grace!
01-22-2022 04:16 - edited 08-10-2023 03:56
Hi there, @SunsetRunner. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. We‘re taking your comments and sentiments in regards to our products and services into consideration.
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still have questions or concerns, please feel free to contact our team back so they can continue helping you.
01-22-2022 04:35
01-22-2022 04:35
01-22-2022 18:44
01-22-2022 18:44
Sounds like a faulty product. My daughter is having the same problem with hers and it’s less than a year old. I’m trying to figure out how to fix it but like you, we have tried various suggestions but nothing has worked so far. Please post whatever your outcome. Thanks!
01-22-2022 19:10
01-22-2022 19:10
01-23-2022 06:10
01-23-2022 06:10
@MarreFitbit @Fitbit I have not had any further response to the issues concerning my Fitbit tracker?
I would very much appreciate hearing from you.
01-23-2022 07:05
01-23-2022 07:05
Same problem I have. If I uninstall the app e install again, all work and receive notification for some hours, than again the same problem. Help. Me please
01-23-2022 07:55
01-23-2022 07:55
Hi,
I‘m just looking through the forum as I have a similar problem: My Versa 2 isn‘t giving any app signalization after I‘ve charged it. If I then restart the Versa it works again, but also not constantly. I‘m using it with an iPhone 7.
Best regards
Jürgen
01-24-2022 02:48
01-24-2022 02:48
Hi, I bought my Versa 2 a week ago and the same problem. It worked the first day, after that I have the same message, restart required etc. And the same, nothing helps..
