Notifications are not coming through my Versa 2
The title pretty much says it all. I've done everything on this thread several times & nothing changes: https://help.fitbit.com/articles/en_US/Help_article/1979.htm?Highlight=notifications#Why
4 REPLIES 4
Hi there, @justpeachy242. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
In addition to the steps you've done, please try the following in the order listed:
  • Unpair your Versa 2 from your phone's Bluetooth and Fitbit app.
  • Unpair other Bluetooth devices that you may also have paired to your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off other Bluetooth connections when not in use. This can help to prevent connectivity issues or Bluetooth interference.
  • Turn on the Bluetooth on your phone.
  • Plug it into the charging cable and open the Fitbit app.
  • Set up your Versa 2.
  • If there is no connection, restart your Versa 2.
  • Set up notifications again.
  • Once your Versa 2 is paired and syncing, please proceed to set up your other Bluetooth devices to your phone again.
With the steps above, what I want you to do is to pair your Versa 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Hi Marre,
Thank you so much. This is what I've been doing & it's not working. I just got this one as a replacement. Is it possible it's just defective?
@justpeachy242 Thanks for following the tips and recommendations I provided above.
With the information you've provided, I'd like to know if you did remove your old Fitbit device from your phone's Bluetooth settings?
Yes I did.
