Notifications are not coming through my Versa 2
My Versa 2 has suddenly stopped showing notifications at the start of each day and showing up that it needs to share system notifications - have already done that but having to force close the Fitbit app, rebooting Bluetooth to get it working again.
3 REPLIES 3
Hello there, @TomM23. Thanks for stopping by in the Fitbit Community Forums and trying to troubleshoot the issue with your Versa 2 before reaching out.
May I know what Android phone you have? I'd like to provide the following steps that actually work for Huawei users, but whether you have an Huawei, I'd still suggest the following steps:
  1. On your phone, open the Settings app > Apps and notifications > Apps.
  2. Tap Fitbit > Battery.
  3. Turn off the Power-intensive prompt option.
  4. Tap Launch.
  5. Turn off the Manage automatically option, and turn on the Auto-launch, Secondary launch, and Run in background options.
  6. Tap OK.
Note that you may see a message on your phone related to power consumption and apps scanning in the background. If you follow the steps in this message, the Fitbit app can’t run in the background and certain features may not work properly. Repeat the steps above to enable the Fitbit app to run in the background.
I have an iPhone XR.
@TomM23 Thanks for the information provided.
In addition to the steps you've done so far, please try the following in the order listed:
  • Unpair your Versa 2 from your phone's Bluetooth and Fitbit app.
  • Unpair other Bluetooth devices that you may also have paired to your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off other Bluetooth connections when not in use. This can help to prevent connectivity issues or Bluetooth interference.
  • Turn on the Bluetooth on your phone.
  • Plug it into the charging cable and open the Fitbit app.
  • Set up your Versa 2.
  • If there is no connection, restart your Versa 2.
  • Set up notifications again.
  • Once your Versa 2 paired and syncing, please proceed to set up your other Bluetooth devices to your phone again.
With the steps above, what I want you to do is to pair your Versa 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
