01-07-2021 07:55 - last edited on 12-18-2022 20:47 by MatthewFitbit
My fitbit versa 3 will connect to my phone and i can answer calls but keeps knocking off and saying "notification service not running. A phone restart is required to re-enable notifications on your tracker". I have reset both phone and fibit. I have to uninstall and reinstall the app about 3 times a day 😠.. I only got it at xmas at my wits end
01-07-2021 13:57 - edited 11-16-2023 03:17
Hello there @Karso88, welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3. I understand how you must be feeling.
Thanks for answering @Guy_'s question. For the latest list of devices that support the Fitbit app for Android, see Which phones and tablets can I use with my Fitbit watch or tracker?
If you're exactly getting this error message “Notification service is not running. A phone restart is required to re-enable notifications on your tracker”, please note that we’re aware of it and are working to identify a resolution as quickly as possible.
If you're not getting that error message, make sure you've followed these steps: Why are notifications delayed or missing?
Since you're on a Huawei phone, you can also try the following steps to see if that helps:
Note that you may see a message on your phone related to power consumption and apps scanning in the background. If you follow the steps in this message, the Fitbit app can’t run in the background and certain features may not work properly. Repeat the steps above to enable the Fitbit app to run in the background.
Let me know if you have any questions present.
01-07-2021 10:13
01-07-2021 10:13
What phone do you have?
Are all permissions granted for the Fitbit app?
Are things being shutdown from battery optimisation, to save power, if the phone is lower on power?
01-07-2021 13:41
01-07-2021 13:41
Its a huawei p20.. Yes all permissions are on. I changed all the battery to manual earlier! Im due an upgrade for my phone. Any idea what would sync to the versa 3? Other than apple.
01-07-2021 14:22
01-07-2021 14:22
Thanks @MarreFitbit i had already followed those steps with no luck. writing in here was my last resort! That “Notification service is not running. A phone restart is required to re-enable notifications on your tracker”,is what I am getting after about an hr of being connected. Extremely frustrating 😕
01-08-2021 04:29 - edited 11-16-2023 03:00
@Karso88 You're welcome! Thanks for following the tips and recommendations I provided. I understand how frustrating this can be.
Since you're getting that error message, please note what I shared with you above as we're working to identify a resolution as quickly as possible.
We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
Thanks for being a Fitbit customer!
01-30-2022 12:30
01-30-2022 12:30
Has this issue been resolved yet please? Having these problems and none of your suggestions have worked so receiving no texts or WhatsApp which was one of the main reasons for having the watch.
06-26-2022 13:59
06-26-2022 13:59
Hello customer service...nothing suggested helps, please advise on a solution. I have a Blackberry Key2, my Versa 2 worked fine with the Key2.
06-26-2022 23:12 - last edited on 11-16-2023 03:29 by MarreFitbit
Hi @Moose24 - make sure the Versa 2 was properly removed because the app may be trying to send the notifications there instead of the Versa 3.
To be really sure,
