Notifications are not coming through my Versa 3
ANSWERED
I purchased my new versa 3 and the notifications are not displaying.I am getting the following error message even after restarting the phone.
"Notification service not running. A phone restart is required to re-enable notification on your tracker".
1 BEST ANSWER
Accepted Solutions
Hi there, @Jyothisivaraman. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
Regarding the message “Notification service is not running. A phone restart is required to re-enable notifications on your tracker”, please note that we’re aware of it and are working to identify a resolution as quickly as possible.
I'd like to provide the following steps that actually work for Huawei users; however, if you have another Android phone, I'd still recommend to give them a try:
  1. On your phone, open the Settings app > Apps and notifications > Apps.
  2. Tap Fitbit > Battery.
  3. Turn off the Power-intensive prompt option.
  4. Tap Launch.
  5. Turn off the Manage automatically option, and turn on the Auto-launch, Secondary launch, and Run in background options.
  6. Tap OK.
Note that you may see a message on your phone related to power consumption and apps scanning in the background. If you follow the steps in this message, the Fitbit app can’t run in the background and certain features may not work properly. Repeat the steps above to enable the Fitbit app to run in the background.
1 REPLY 1
  4. Tap Launch.
  6. Tap OK.
