Notifications are not coming through my Versa Lite
ANSWERED
My versa lite does not recieve my notifications anymore. It shows on the app that there is a phone restart needed but I have restarted my phone several times and shut down the tracker emd switched it on again. I have also uninstalled and reinstalled the app and it is not working.
1 BEST ANSWER
Accepted Solutions
Hi there, @SunsetRunner. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa Lite before reaching out.
If you're getting this error message “Notification service is not running. A phone restart is required to re-enable notifications on your tracker”, please note that we’re aware of it and are working to identify a resolution as quickly as possible.
However, if you have a Huawei phone, you can also try the following steps:
  1. On your phone, open the Settings app > Apps and notifications > Apps.
  2. Tap Fitbit > Battery.
  3. Turn off the Power-intensive prompt option.
  4. Tap Launch.
  5. Turn off the Manage automatically option, and turn on the Auto-launch, Secondary launch, and Run in background options.
  6. Tap OK.
Note that you may see a message on your phone related to power consumption and apps scanning in the background. If you follow the steps in this message, the Fitbit app can’t run in the background and certain features may not work properly. Repeat the steps above to enable the Fitbit app to run in the background.
1 REPLY 1
  4. Tap Launch.
  6. Tap OK.
