02-08-2024
16:14
04:18
02-08-2024
16:14
04:18
Cannot get any notifications to come across my versa lite
Best Answer02-08-2024 19:55
02-08-2024 19:55
Hi @JenW1108 - if it was working and stopped have you tried restarting the watch and fully syncing?
One of the problems with the new V4 Fitbit App is it can lose connection and then you won't get notifications.
It is also worth checking your watch settings in case it is in sleep or do not disturb mode.
Long press the button or pull down on the watch once and then again, and then tap on the 2 white bars to get to Quick Settings and check.
Best Answer02-09-2024 04:22
02-09-2024 04:22
Hi there, @JenW1108. Welcome to the Fitbit Community Forums. It's sad to hear that your notifications are not coming through your Versa Lite. We're here to help you!
As @Guy_ has mentioned, I'd recommend checking whether your Versa Lite is in sleep mode. When sleep mode is on:
If the above doesn't describe your issue, please see Troubleshooting quick tips for iPhones and/or Why are notifications delayed or missing? depending on your phone.
