02-14-2022
19:19
20:28
02-14-2022
19:19
20:28
I recently got the Versa 3 and was excited abt being able to answer my phone on it. However, whenever I do, the caller complains of a horrible echo on their end, to the point where they hang up. Has anyone else had this problem?
02-15-2022 05:41 - edited 10-30-2023 04:17
Hi there, @DACS. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with the on-wrist call feature.
If you haven't done so yet, please check the following requirements:
If you continue having issues, try the following troubleshooting steps:
Note that Versa 3 Controls might be listed as “Not Connected” in the list of Bluetooth devices on your phone. When you receive a phone call, the controls automatically reconnect. This feature requires more frequent charging.
On a side note, please note that if you're trying to connect any headphones while using on-wrist calls, specially Airpods, at this time Fitbit smartwatches can't control the volume on Apple Airpods.
Hope this helps.
02-14-2022 20:16
02-14-2022 20:16
Hi @DACS - echoes could possibly occur if the phone microphone is also on or sometimes too close to the caller.
Try restarting both phone and watch in case there is a conflict.
To clear any problems that might also be due to the Fitbit App, clear it's storage cache and force stop it and also logout and login, for Android phones.
Hope this helps.
