03-21-2022
03:11
20:17
03-21-2022
03:11
20:17
I had been able to answer my phone calls on my Versa 3, but now I am no longer able to answer. The phone calls ring through and I can hang up the calls, but when I try to answer it says there is no connection on my Bluetooth. I have tried to connect th Bluetooth but it won't connect. What should I do?
03-21-2022 06:47 - edited 11-26-2023 16:22
Hi there, @jradams. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
If you haven't done so yet, please check the following requirements:
If you continue having issues, try the following troubleshooting steps:
Note that Versa 3 Controls might be listed as “Not Connected” in the list of Bluetooth devices on your phone. When you receive a phone call, the controls automatically reconnect. This feature requires more frequent charging.
Hope this helps.
03-21-2022 05:02
03-21-2022 05:02
Hi @jradams - in the Fitbit App click profile photo, device photo and On Wrist calls. If that doesn't work remove Versa 3 controls from the phone's Bluetooth and try again. see How do I take on-wrist phone calls with my Fitbit smartwatch?
Hope this helps.
