05-10-2018
08:57
07:03
AlejandraFitbit
05-10-2018
08:57
07:03
AlejandraFitbit
I would like to receive the notifications on my Versa but I don't want the Versa to vibrate every time I receive notifications, because that's very annoying while I receive a lot of notifications.
Is it possible to turn off vibrations?
05-10-2018 09:12
05-10-2018 09:22
05-10-2018 09:22
It's not in the strong-mode but in the normal mode.
But it's very annoying that every time I receive a notification the Versa vibrates.
It is possible to receive notifications on my Versa and that it's not vibrating.
08-19-2018 22:31
08-19-2018 22:31
I am also looking for the same ..i want to turn of this vibration ..it is very annoying ...i am not feeling comfort on the notifications part
08-20-2018 07:05
08-20-2018 07:05
It's great to welcome you @girishkumar518.
If you don't want your Versa to vibrate at the moment of receiving a notification, you need to have your phone on "Silent" or "Do Not Disturb" mode, then go to the Fitbit app, go to notifications and turn off the "Always Vibrate" option.
I hope this helps, catch you later.
01-12-2019 15:42
01-12-2019 15:42
My app doesn’t have that option and i have the versa as well. There is no “always vibrate” option.
05-27-2019 01:51
05-27-2019 01:51
Hi there, is this perhaps only an option on android phones/apps? I'm trying to turn off the always vibrate option but I cannot find the button in the iOS app.
Looking forward to your reply!
06-28-2019 11:56
06-28-2019 11:56
Using Android 9 (P or Pie), open fitbit app, then tap on the watch icon in upper right (where the battery indicator is). Then scroll down a bit under General heading. Should see Notifications options. Click on that. I turned everything off, put my phone in the Do Not Disturb mode, then did a happy dance.
09-17-2019 05:06
09-17-2019 05:06
So no solution to this? I want notifications but no vibrations. There’s no “always vibrate” option on the app for iPhones!
12-03-2019 06:20
12-03-2019 06:20
I was wandering how to change the intensity of the vibration?
12-04-2019 07:39
12-04-2019 07:39
It's great to see you around, @Nicole_danielle.
Regarding your inquiry, you have to swipe to settings and then tap the vibration option and select the one you like the most. You can also check the Versa Product Manual.
Let me know if you need anything else. 🙂
02-10-2020 15:01
02-10-2020 15:01
This doesn't help. I think most people figured that super basic setting out. You could have just said "no, it's not possible". Would be nice to see the option in the future
04-28-2020 16:25
04-28-2020 16:25
I for one am ready to trash my fitbit versa. I have been burned while taking a dish out of the oven when my fitbit starts vibrating and tells me to get moving. I am in the middle of moving! All notifications are off except low battery. I have dropped numerous objects from being startled by that darn vibration.
06-19-2021 08:08
06-19-2021 08:08
I’m also a year looking for that option. Why not “strong”, “normal” and “off”.u
I used to have a Pebble. That one was much better with notification settings and vibration. The Pebble vibrates for incoming calls, but turned of for notifications.
Fitbit you took over Pebble, why you don’t use that feature!
And no, I don’t want to use the “do not disturb” settings, that’s not the answer to this.
10-23-2022 01:28
10-23-2022 01:28
There is no option not to vibrate. There was on previous models. My versa 3 is driving me insane
01-13-2023 14:52
01-13-2023 14:52
Strongly agree. I hate the vibrations so much that I only wear it when I am walking or running.
Needs an Off option.
