05-12-2019
03:54
10:56
DavideFitbit
05-12-2019
03:54
10:56
DavideFitbit
I have everything on my Versa Lite set to metric. Weight, length etc etc is all metric.
But when I run, the units are showing in miles and the cues are every 0.5miles instead of 1km as it it set. How do i change this to km instead of miles?
Best Answer05-12-2019 06:03
05-12-2019 06:03
Hello @Saharanz and welcome to the Help forums. I want to clarify something -- when you mention the unit settings, do you mean just the units in the Advanced Settings in the app? There are also Cue Settings for each of the different exercises that measure distance. Here's how to find the Cue settings. From your app dashboard go to Versa Lite > Exercise Shortcuts > Run. Go down to Run Cues and make sure they are set to metric. It looks like the default setting is miles.
Laurie | Maryland
17:02
10:56
DavideFitbit
07-25-2019
17:02
10:56
DavideFitbit
So I have the same problem with my dads Versa Lite. All settings set to metric but the pace is in inches... I have already down what you suggested above. Any other tips pls?
Thanks in advance for any help. Driving me mad!!
Moderator edit: format
