04-23-2018 14:48
04-23-2018 14:48
I cant pair my airpids
08-19-2018 05:18
08-19-2018 05:18
Then we’re you Abel to pair back up with iPhone so you have both your Fitbit & your phone paired at the same time?
08-19-2018 05:44
08-19-2018 05:44
09-03-2018 05:53
09-03-2018 05:53
thank you so much for your help I was very confused on how to connect my airpod and just a very big thank you
09-03-2018 05:55
09-03-2018 05:55
go to the Bluetooth menu in your fitbit hold the button on the back of your airpods and it will find them
11-30-2018 15:57
11-30-2018 15:57
when your fitbit is looking for a new divice, hold the button on the back of the airpods until it connects.
12-29-2018 14:18
12-29-2018 14:18
You're a freaking genius! I never knew there was a button on the back. I've been trying to pair them for 2 days now! TY TY TY!!!!
12-31-2018 05:25
12-31-2018 05:25
I didn’t know about the button on the back of the Airpods. Thank you this worked!
01-01-2019 06:29
01-01-2019 06:29
01-26-2019 13:55
01-26-2019 13:55
the key is that the button is on the back of the airbuds CONTAINER
05-06-2019 23:10
05-06-2019 23:10
Thanks your way worked. I didn’t remove my AirPods from my iPhone though. I put AirPods back to its case, kept pressing the button at the back of case and they showed up on the watch.
05-10-2019 21:46
05-10-2019 21:46
This totally worked! I didn’t even know there was a button on the back of the AirPod case. Also, a tip for others: the case needed to be open on mine to pair, so I pushed the button while the case was open.
06-24-2019 19:17
06-24-2019 19:17
Thank you! The holding on the back of the case helped me!
10-29-2019 18:58
10-29-2019 18:58
I was able to connect - but, I cannot adjust the volume using the Versa. Anyone have a solution?
10-30-2019 01:30
10-30-2019 01:30
01-30-2020 18:54
01-30-2020 18:54
Yes,me too it finds my sorrows but when I try to connect it loads for so long to the point I just forget about it it's to **ahem**ing weird.
04-12-2020 04:49
04-12-2020 04:49
Thank you so much for your clear and easy to follow instructions, it finally worked for me. I never knew there was a button on the back of the AirPods container!
04-18-2020 14:41
04-18-2020 14:41
Every time i tried to connect it, it just keeps showing the loading screen on my watch for a long time.
04-19-2020 02:18
04-19-2020 02:18
04-19-2020 08:02
04-19-2020 08:02
05-17-2020 12:59
