Pandora Stations never change on versa
 Hello,
I always thought that the stations you play the most on Pandora are the ones downloaded on the Versa. I'm listening to one particular station on Pandora (all day everyday) but it doesn't get downloaded to my Versa. How do I update my 3 stations on Versa?
Thank you for your time,
Didi
2 REPLIES 2
The update occurs when it is charging in the location where the wi-fi you set it up with. I suggest plugging it in where the wi-fi signal is (home, office, wherever you have it linked) then while it is charging, manually sync the unit and then leaving it alone for about an hour or so. It usually takes a few minutes for the unit to link up via wi-fi to Pandora and then start the download. It takes about 15-20 minutes per station to download.  Try this and see if it works.
While your Fitbit charges or you just want to catch your breath, join us on the Lifestyle Discussions
Community Council Member
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
That's what I do every morning. Plug in to my laptop with wifi of my home (where I have it linked). I do see Pandora updating but I think it only updates the Thumbprint radio not the stations... Is it maybe a songwriter's authorization from Pandora or something?
