09-30-2018 20:31
09-30-2018 20:31
Best Answer10-01-2018 08:36
10-01-2018 08:36
Thanks for the troubleshooting you've already done, that will save a lot of time. Have you tried re-pairing the connection between the Versa and Bluetooth? Go into the Bluetooth settings and select "Versa". Then unpaid the Versa and it should show up in the list of discoverable devices. Select it, and you should be good to go. It may take a few tries, especially if the phone isn't supported by Fitbit (another reason why you may be having trouble!).
Once the connection is restored, try to sync again and see if that helps.
one cruise ship at a time!
