06-25-2019 07:51
06-25-2019 07:51
I Upgraded it to the versa from the Alta primarily in order to be able to listen to music using apple airbuds. They link, And I’m going to get him to play music on Pandora it says that no at part source is found. Even though in settings it says the air buds are connected. Also the lack of volume is beyond frustrating. I have tried to go around I have linking it to my iPhone first to change the volume and then linking it to the versa. But the volume goes right back up to Max. I am considering returning this versa. It is very frustrating.
06-25-2019 07:53
06-25-2019 07:53
Correction Apologies for the typos. When I try to play music from Pandora, it says no output source found, although I successfully “paired” and it shows AirPods connected under settings. I have reset the versa twice. And still have this issue.
06-25-2019 10:49
06-25-2019 10:49
Do you use the paid Pandora subscription? I am also trying to figure this out.
