04-22-2018
07:05
12:44
MarcoGFitbit
04-22-2018
07:05
12:44
MarcoGFitbit
Has anyone found a resolution to the Pandora stations not downloading to the Versa? This thing is being returned tonight if I can't get it resolved after working on it for 3 days!
04-23-2018 12:55 - edited 04-23-2018 12:55
Hello @IndyNurse, I hope you're doing well, it's nice to see you around. ![]()
Thanks for bringing this issue about downloading Pandora stations to your Versa to my attention. First of all, I would like to suggest you to restart your Versa by pressing and holding the Back and Select buttons (left and bottom right) until you see the Fitbit logo on the screen and double check you're following these steps to download the stations.
If your Versa is still unable to download stations plug your watch into the charger. Stations download automatically when the watch is charging and in range of your Wi-Fi network, or tap Force Sync Now in the Fitbit app to add the stations to your watch.
If the issue persists, please try the following:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
04-23-2018 13:55
04-23-2018 13:55
04-26-2018 21:50 - edited 04-27-2018 11:35
This is so frustrating. I have been trying to sync my Pandora stations all day. I got the point that I removed all but 3 stations from my Pandora Premium account. All that will sync are 2 stations. One time the downloading got to 86% and then stopped and the same 2 stations downloaded. I have removed Pandora and also unlinked my watch from Pandora, re-booted the watch and iPhone multiple times with the same result.
Update: 4/27/18
I followed the above steps again, re-booting both iPhone 6 and Versa, unlinked and re-linked Pandora, etc. The was showing the download progress and stayed on 22% for about 30 minutes. When checking Pandora app on the watch, tha same 2 playlists were showing. That is fine, however, why did the iOS app stop at 22% but stations were loaded. Also, why won’t the third station download? I only have 3 stations in Pandora so all 3 should download. Something appears wrong with the buggy Fitbit iOS app as it does not consistently work.
Update #2 - 4/27/18
I am either stubborn or determined to get this to work. Without resetting the watch or unlinking Pandora, etc., I put the Versa in the charger and on the Fitbit app I connected the watch to wifi and then went to the Pandora app and chose force sync. On the mobile app, it showed the progress slowly going up. After and hour it was stuck, AGAIN, this time at 42%. I waiting and checked the Versa and all 2 station now show, FINALLY, after 3 days of trying.
I believe there is a definite disconnect somewhere between the Fitbit app, Pandora app and the Versa. Adding music/stations to any device should not be this difficult.
05-25-2018 04:38 - edited 05-26-2018 20:40
I am now having this problem after a week of intermittent stration updates. Now the pandora app has disappeared from my media in the Fitbit app but still shows installed in my apps. This is day two on this particular issue ugh.
Best Answer05-26-2018 04:56 - edited 05-26-2018 20:41
Update* first excuse my auto correct 😉 I have unlinked, linked, restarted the versa, uninstalled, installed, moved to every possible place in my house for the "strongest" signal even tried to use the phone as a hotspot....nothing. I have Sirius and now paid for pandora in the hope of getting this very expensive smartwatch to work how it should. Ugh HELP Fitbit! I don't want to return it but I just might
05-29-2018 07:38 - edited 05-29-2018 07:39
Update ..again* spent an hour on the phone last night, still no results. I will call again tonight and see this attempt through. This is ridiculous, I wonder how many people are having this issue???
05-30-2018 06:22
05-30-2018 06:22
Update..after yet another hour on the phone doing no more than I am capable, and have done, on my own I have been told the issue has been escalated and that I will receive an email. Very disappointing.
Best Answer06-08-2018 14:38
06-08-2018 14:38
Didn't work. Have any other great magic tips?
Best Answer06-08-2018 15:25
06-08-2018 15:25
I returned the original thinking maybe it was faulty......nope! Got the new one and still the same problem
06-14-2018 11:40 - edited 06-14-2018 11:42
Instructions DID NOT work! It appears so many people are having the same issue and apparently this problem has been going on since Mid May. What is Fitbit doing to resolve this. This problem is a month old.
06-17-2018 20:55
06-17-2018 20:55
Ok I just bought two of the fitbit versa for the sole fact that they can connect to pandora and I can not get either one of them to connect. I have search the web and there is a ton of people in the same boat. Has anyone found a solution? This is my 3rd fitbit upgrade and I love them but this might be the push to get the apple watch if they do not figure this out soon. FIt bit help!
06-18-2018 04:46
06-18-2018 04:46
I too got it for the music and NFC(my bank isn't even on list) but I have since accepted the loss of downloading pandora, for now, and simply uploaded my own music. It's still a great buy considering the other prices out there. But I am going to get my husband a blaze that does much of the same without the pandora headache.
I have faith fitbit will fix this
Best Answer06-18-2018 06:37
Bronze Community Members are highly active users who have shared their knowledge for the betterment of Fitbit products and services. Learn more
06-18-2018 06:37
@IndyNurse wrote:Has anyone found a resolution to the Pandora stations not downloading to the Versa? This thing is being returned tonight if I can't get it resolved after working on it for 3 days!
It was a slow process but I moved the Fitbit, phone, and charger into the same room with my router and tried to forget about it for a half hour. My stations then downloaded successfully. I also noticed that they updated over WiFi the last time I charged my tracker. Good luck.
Best Answer06-18-2018 07:59
06-18-2018 07:59
I'm glad it's working for some when I first got it, it worked for 2 days then I woke up one morning and nothing was there. I got my first pandora notification on it about an hour ago. That never happened before..... maybe something changed. 🙂
Best Answer06-18-2018 09:22
06-18-2018 09:22
06-18-2018 09:24
06-18-2018 09:24
Best Answer06-21-2018 18:13
06-21-2018 18:13
Nothing changed still won't load anything from pandora.
06-22-2018 23:12
06-22-2018 23:12
I tried downloading it with my phone hotspot and it didn’t work but once I connected my laptop to the hotspot and tried downloading pandora it worked... took like 2 hours but now everything is synched. I hope it works for you all 🙂
Best Answer06-27-2018 16:41
06-27-2018 16:41
I have tried all of that and still no luck. Very disappointed in the versa
