04-22-2018
07:05
12:44
MarcoGFitbit
04-22-2018
07:05
12:44
MarcoGFitbit
Has anyone found a resolution to the Pandora stations not downloading to the Versa? This thing is being returned tonight if I can't get it resolved after working on it for 3 days!
09-06-2018 09:46
09-06-2018 09:46
Best Answer09-06-2018 09:49
09-06-2018 09:49
For my S8 its under connections - data usage -
Best Answer09-06-2018 10:34
09-06-2018 10:34
In my Moto X4, it is under Network & Internet, Data usage. Unfortunately, Fitbit already has Unrestricted data enabled. I added Pandora to the Unrestricted data list.
Best Answer09-06-2018 12:15
09-06-2018 12:15
For me it was not the Fitbit app that was the problem, per se, it was my phone hibernating and/or the wifi timing out, before the Pandora download finished in the fitbit app. So to be clear, it's not the "keep alive widget" in the fitbit app that was the problem. It was the phone settings for data restriction across all apps that was causing the problem. I finally got my music on my Versa though and I hope you folks can too:)
Best Answer10-02-2018 07:22
10-02-2018 07:22
Translation: All those steps simply mean the Fitbit software is fragile and not robust.
Best Answer10-24-2018 18:55 - edited 10-24-2018 18:56
@SunsetRunner to this point is your music still there?
Best Answer10-24-2018 19:02
10-24-2018 19:02
Not on my Fitbit.
Best Answer10-24-2018 19:04
10-24-2018 19:04
Best Answer10-24-2018 19:19
10-24-2018 20:47
10-24-2018 20:47
Best Answer11-01-2018 23:48
11-01-2018 23:48
my versa is having the same issue.. so are the other 2 that my family has.. after 6 months it has quit.. we are so dissappointed and want to return all 3 but we do not have the boxes and stuff anymore.. what a waste of money,
12-03-2018 10:07
12-03-2018 10:07
I performed all these tasks multiple times with no success. I returned the
Versa and got my money back. Cannot believe there is still a problem like this that hasnt been solved after all these months. Will do more checking before buying a replacement to see what really works well for the money.
12-29-2018 22:16
12-29-2018 22:16
My solution was give up. I spent countless hours dealing with this issue. Performed every thing I have ever been told. Even got my ionic replaced, did a factory resets, firmware updates, still nothing. I'm 0-2 on them, literally months into this issue. Now I'm told I'm too far out for a refund. Well no kidding I spent months wasting time on a faulty product because I'm not the type of person to complain about it without trying my hardest to fix it. Now all I get from customer service is the same generic "disconnect and reconnect" suggestions. Total joke. Ive had multiple fitbut products but this will be the last no doubt. Had I known I wouldn't have music, my watch would say "Garmin" on it and it would run flawlessly I guarantee it.
12-30-2018 00:28
12-30-2018 00:28
Best Answer12-31-2018 06:09
12-31-2018 06:09
Right. Don’t offer the option if it doesn’t work. I would have known the wiser. ALSO, don’t offer a faulty option and then make the user feel like a dummy for not getting it to work.
12-31-2018 06:11
12-31-2018 06:11
**I would have been NONE the wiser...**
🤦🏻:female_sign:
Best Answer01-01-2019 01:19
01-01-2019 01:19
Best Answer01-01-2019 09:49
01-01-2019 09:49
Best Answer01-01-2019 09:54
01-01-2019 09:54
7 Hours to download is not "working."
Best Answer01-01-2019 10:03
01-01-2019 10:03
