Please add “seconds” to the always on display
Firstly - someone else suggested this and it was responded by Fitbit as an “existing feature” but it’s definitely not.
I need seconds displayed on the “always on” clock - it’s for my job and it’s a rule so I can’t use the watch if I can’t see seconds.
Please update this as an option. Surely it can’t be that difficult to do? I know it would drain the battery quicker but give it as an option at least.
Thanks
1 REPLY 1
Hello @Finoh
Maybe what would help, since the feature you want isn’t available yet, is to change your clock face on your Versa 2. I would look at SimpleClockPro from the gallery which shows seconds (Digital or Analog) and has an always on directly on the clock face. It might just be what you need.
Here’s how to get it:
Just tap your profile picture on the Fitbit App then scroll down and tap Versa 2 then tap gallery. At the top of your screen tap the magnifying glass and type SimpleClockPro in the search bar. 😉 It’s free
😃 Hopefully this meets your needs and provides you the best answer for your question. Please let me know.
