Press and hold bottom right button versa
Yesterday my versa did open an app when I pressed and hold the bottom right button but now it doesnr anymore. I cant find it in the user manual, does anyone know how this works?
2 REPLIES 2
@SunsetRunner Please take a look at my post here. I mentioned it there. 😄
Marrrmaduke | Canada
Charge HR, Blaze, Charge 2, Charge 3, Inspire HR, Versa Lite, Versa SE, Aria
Hi, when you press shortly the right lower button, it will open the app that's on the first app page on the lower left side. This is called a short cut. The same happens when you press shortly the right upper button, this will open the app on top of the page settings also on the left side. Long pressing the upper button shows you the notifcations, long pressing the lower right bottom: nothing happens. This give you the opportunity to arrange your app in such a way that a short press on one of these two buttons, opens the app of your choice, instead of swiping from the left to the right on your home display to go to the apps page.
