Best AnswerHi @Marko94 I have found with my Versa that it is a bit particular about where you tap it. I have found about half way up the left hand side works best. So experiment with tapping in different places. But your other option is to just press a button. That wakes it up every time.
Helen | Western Australia
Thanks @NellyG and @SunsetRunner. I will try to experiment more.
Also I have few questions from experienced users like you 🙂 :
1. heart rate monitor is always on for you ?
2. notifications also ?
3. any special tweaks, guides to save more battery ?
4. What about backup ? for example, If I change phone or something else. Do I need backup apps somewhere or it is already backuped on Fitbit ?
That is for now 😕
Best AnswerHi, thanks for the compliment.
Regarding your questions:
1. HR is always on
2. Notifications: only calendar events. Do not see the need for more cause I have my phone with me almost always.
3. Regarding battery saving: use a Clock Face with a size as little as possible. Large Clock Faces drain your battery. I can recommend this one:
https://gam.fitbit.com/gallery/clock/364a8989-6105-4418-93aa-10a4e55775ea. Only 49 kB and customizable to your own liking. Play with it untill it's fully to your satisfaction. It's a payed version (only $1.1) after a trial period of 30hrs
4. Backups are not needed as all is already stored on the Fitbit servers.
Heres my answers to your questions @Marko94
I leave HR on as well
Notifications really this is personal choice. I havd calendar events, text and call notifications, but I dont get many so itis not a big drain on the battery. If you gets a lot of notifications then it will run your battery down more quickly.
Battery saving - choose the notifications that are important to you and dont use all day sync (I dont listen to my own advice here), and I agree with @SunsetRunner - choose a clockface that doesnt use a lot of power.
Thanks @SunsetRunner
I forgot to ask one more thing, I am not allowed to edit post 😕
What about brightness ? Atm I have it on auto, is that ok ?
Thank you for new Clock face, will try it.. still searching for perfect one 😛
Btw, if you have any other recommendation, suggestion or info I will be very thankful 🙂
Best regards,
Marko
Best AnswerRegarding brightness: auto is in principle not bad, depending on the Clock Face you're going to use. I have mine on normal and as you have read before, that's not a battery drainer. Like this more than auto.
Hi,
I just wanted to share this Clock face.
It is simple, unique, and very small , 4.67 kb 🙂
Btw I tried what you suggested, it is also nice, my second option 😉
