02-08-2019 10:23
02-08-2019 10:23
Pulse readings jump 30 counts above actual while exercising. The false high reading persists for 10-15 minutes and then drops down to actual. Looking at the graph, the changes are clearly a step change - not a gradual up and down. This only occurs while exercising (treadmill), but not every time.
I wear my Fitbit on my non-dominant wrist with the Fitbit positioned 1 inch from the wrist joint. The fit on my wrist is comfortable snug.
Best Answer02-08-2019 11:04
02-08-2019 11:04
I assume you are referring to your heart rate count. If you are, that’s pretty typical.
If you don’t believe it’s correct, I suggest using a different device to check.
I use my polar hr reader and it’s very close...
let me know if you have any questions.
Best Answer02-08-2019 12:27
02-08-2019 12:27
Mine thinks my HR is 175, sudden change. Yes I'm exercising, but my actual heart rate is about 110 what gives? I just updated last night did that screw it up?
