Purchased and past selected Watch faces
Hi,
just got my Versa today and purchased a face and then decided it didn’t like it so I got another one! My question is, is there a place that you can go to, to access your purchased faces incase I want to use it again in the future? The only option I can see at the moment is to just browse and find it!
Thanks in advance
2 REPLIES 2
Hi, you can always reinstall purchased Clock faces. It's indeed so that you have to search for the purchased Clock face and install it again. Once it aske for a code to enter, do this: Once you have purchased a Clock Face and deinstall it and want to reinstall it, you will get the message "already payed" option. If you do not get this option, choose the option "End Trial" and go to kzl.io./code, enter the code displayed on your Versa, press it, enter your email adress  and your clock face will be installed again.
@Leaby I dont think there is a place you can go back to check your purchased clock face. If you replaced it, you might need to repay again!
I have a YT channel started so fitbit versa users can have an idea on different clock faces before installing them. Free clock faces is better.
Hope you check out my channel, thanks for your support.
https://www.youtube.com/channel/UCsnsyXD2HU5jWcIcNJXBrrw
