Quick settings option missing on my fitbit versa special edition
ANSWERED
Quick settings option missing on my fitbit versa special edition.
Also would like to highlight that I am seeing a dot on right side of screen. Is this some sensor?
Please help how to get quick settings
-Thanks
1 BEST ANSWER
Accepted Solutions
Resolved..
Did factory reset and many new features got visible along with quick settings
17 REPLIES 17
In order to check it is not a temporary problem best to charge the watch and restart it
Shut down the watch
[ Swipe left, Settings,
at the bottom, About,
at the bottom, Shutdown]
wait a minute
Start the watch
[Hold the button till it vibrates or logo appears]
Wait for the clock to reappear.
Done. Still no where i can see quick settings options/menu.
I just bought it yesterday
Are you pulling down from the very top of your watch twice.
Once to see your messages and again to get to quick settings?
Yes .. but post pulling it just shows notification and no quick settings options.
I tried twice thrice many times
Are you pulling down from the VERY top of the watch?
Also can you verify the version of firmware in your Versa
In the phone Fitbit App
Click on profile photo [top left]
Device photo [middle left]
Version at the top
or
On the watch
Swipe left
Settings
Scroll to the bottom
Click About
Version at the top
Yes from the very top.
Firmware version
32.33.1.30
That version is incredibly old and didn't have the feature way back then.
See Latest Firmware list
That version for OS 3.0 was announced in 2018.
If you are happy with the watch otherwise, and aren't experiencing any issues, probably stick with it. Definitely at the moment.
Thanks. Is there any option by which i can upgrade the firmware version to latest one as I am not seeing any update currently
Unless there is a problem don't upgrade but if you want new features [and problems] contact Fitbit Support directly. They may be able to help you.
You can't choose to upgrade even though the option is there.
Help & Support
Check for ... update
Thanks. I did a factory reset and the version got upgraded and also i have started seeing more features including Quick Settings:
Firmware version 32.72.1.9
Thanks for the feedback. Hope you don't run into problems.
With the older versions, quick view was accesses with a swipe from left to right, the later by holding in the button.
Once you pull the screen down the second time press the two white marks. Thats quick settings.  It doesn’t say quick settings anywhere.
Resolved..
